I had one of the first EMS kits. Four years later now it still works fine. 35 spline shafts all the way and 4. 30 gears.
I have had issues with the "Green Grease". It was heavily touted in all the big off road magazines. So I tried it. Big mistake. I had all kinds of bearing issues with the front end. Then I went to good old lithium based, standard wheel bearing stuff and I have not had a problem since. I take my truck surf fishing a couple times a year so that means a week of splashing through 3 feet of salt water and sand so my durability testing is good. The bearings would set up fine but would get loose quickly and let some water in. I also think the green grease was so thick that it would not liquefy and lube the bearing as it should have. I am an experienced, professional mechanic and have set up hundreds of bearing sets so I know how it should be done. During my problem time my buddy with a Ford did a Dynatrac conversion and used the green grease and had the same problem with the bearings. We went to the beach and after we came back had the same problem and loose hubs, both of us switched to the regular grease and have had no problems since.
And the guys at EMS still remember me. I can't speak highly enough about them. Excellent support and always willing to answer questions.
