DMAX boys fighting Gas Wara
BEAUTIFUL W350 Whos is it?
Pyrometer Tales...
They ought to...
pull that same trailer and hill with some of the Cimmins' on here. Can you say "8. 1 got smoked by a little 5. 9 Cummins?":p
poor gm boys
no wonder we all keep blowing the door off of the GM trucks,,,,,,,,,, that cant even figure out the difference between torque and horsepower
Horsepower is torque X rpm over a mathamatical constant right
The gas can have less torque but turn more rpm,,,,, therefore more horsepower
this is why there are very few things that can compare to a 12valve that will turn 4grand plus
I had a 99 Suburban 2500 with the 7. 4 liter, 4l80E trans, and 4. 10 gear before I bought this dodge, and I said the same thing.
My suburban could run circles around this dodge, with and without the 12k load behind it.
And I suspect that even the new gen. cummins wouldn't stand a chance either... .
Them are the facts.
But when we get into the longevity of the engine, and fuel mileage... Cummins gets my vote... I guess.
Re: poor gm boys
Correct.
One horsepower is defined as 550 ft-lbf/sec. Converting RPM to radians per second (*2*pi / 60) and solving for (brake) horsepower gives us:
BHP = Torque * RPM / 5252
Since the power band (or should I say torque band?) in our trucks is pretty much flat from 1600 to 2700 (in the 24V, anyway), horsepower increases linearly in that band, with the peak being at 2700, then dropping off slowly to 3200, where the torque really heads downhill, and drops quickly to near zero at 3500.
--Ty
from the dyno
At 1567 rpm I have 98HP/330FTLB.
at 1884 it is 255/705,
at 2200 try 385/925,
THEN it flattens out the HP stays up past 3100 and the torque drops to 650 over 3000.
Also according to the dyno, peaks are at 2250 and 2500.
yeah, yeah, I should post the darn graph.
:p
Originally posted by curatchko
I had a 99 Suburban 2500 with the 7. 4 liter, 4l80E trans, and 4. 10 gear before I bought this dodge... ...
What had you done to that Suburban? Or is your Dodge one of the rumored early gutless 24 valvers? My 91 has stock injectors, no intercooler, 260K, and doesnt smoke too bad with one injector stuck open. It will still outpull ANY V8 I have EVER driven, gas or diesel. Maybe the mechanical ones pulled better? Or the 454s, 460s, V10s, etc, have just been bad apples. Either way, you are entitled to your opinions, but in my experience, nothing compares to the Cummins, in pulling power, fuel economy, or longevity. AND, I can start a load without having to rev up, unlike most of the V8 crowd; How many of them can dump the clutch in 3rd (empty) and not kill the engine? (I know, the stock clutch complains when I do that, but some ricers need a good dose of smoke now and then)
Daniel
Daniel
I have a fueling box and some other mods now that make my 24v pretty healthy, but as you said, my 24 valver was totally gutless when I bought it. I couldn't go over 60-65 mph stock..... and going through overpasses on the freeway would lose me 10 mph... . did all the reflash stuff, took it to cummins, chrysler... . did the whole investigation and it's just a pig stock. Even now when I turn that box off it will not pull my trailer for beans.
The Vortec 454(300 horse, 405 torque) I had never quit pulling, and accelerated very quickly... I could take it through mountains without barely a strain with the trailer... .
Furthermore, a good friend bought an 03 about this time last year and it's a pig too... . couldn't do over 65 pulling his 6k travel trailer!!!! Has a box on it now and it's woken up but again, without the box it's a pig.
These are my only 2 diesel experiences. If it wasn't for TDR I'd gotten rid of this truck a long time ago.
No compaints now cuz I get great mileage and have lots of power. But I am taken back when I see people tell me how great diesels pull... . They don't from the factory!!!
Ain't no way any diesel, Ford GM or Chryser is going to out pull that 8. 1 Big Block chevy, off the show room floor. Just ain't gonna happen.
stock Cummins
I'm stock for now.
I have a high front end (wind resistance) travel trailer, loaded, it is 7500 to 8000 lbs. without OD, I can maintain 65 mph going up a 6% grade on the Dames point bridge (over the st johns river). 6% is 6 feet in height in 100 feet horizontal. That is double of most Interstate overpasses. I think some trucks are pigs and some are decent from the factory. I can only imagine what my truck will do with another 60 hp/120 trg added to it. :D
Pulling the same 36' long, 13'2" tall 13,500 lb 5th wheel up the same 6% grade (westbound I-10 going into Kerrville, TX), the results were:
1996 Dodge 3500 V-10 (300/450) automatic, 3. 54's
55 MPH @ 3500 RPM in 2nd gear - full throttle
2002 Dodge 3500 (see signature)
70 MPH @ 2350 RPM in 6th gear - 2/3 throttle
Fuel economy towing was 6. 5 MPG for the V-10, 10. 5-11. 0 MPG for the Cummins.
Rusty
From Mr. ZF's posts:
Wow, misinformation about the definitions of torque, rpm, and horsepower, and the relationships between them, still run rampant.
I don't know if I have the energy for this again.
Horsepower alone describes the performance capability of an engine, whether it's accelerating or maintaining a speed against a load or whatever. That's a fact, not an opinion. Any engineer worth the paper his degree is written on will tell you. Hell, forget the degree, anyone who's been through Physics 101 and even came close to understanding the material knows the same thing.
Without going into the whole spiel explaining the why's and how's, just consider a couple of things if you doubt me:
1) When you come to a hill and the truck starts slowing down, can you climb the hill faster at your engine's torque peak or by downshifting and putting the engine at it's horsepower peak? Hint: at the engine's horsepower peak, more torque is available at the rear wheels for a given speed even though the engine isn't making it's maximum torque. The additional rpm of the engine allows additional gear reduction which makes more torque at the rear wheels which more than makes up for the engine's torque.
2) On a more basic level, consider this. Horsepower = (torque x rpm) / 5252, right? You can get this formula out of any physics book. Think about it in relation to the rear wheels. If you keep rear wheel rpm constant (i. e. the speed of the truck), doesn't more rear wheel horsepower mean more rear wheel torque? Doesn't the formula say it has to?
That's as far into this as I want to get sucked. There's a whole big multi-page discussion on it if anyone cares to go read it. You gotta let go of preconceived notions though.
posted 01-22-2003 01:03 AM
TG, what moves the truck, torque at the engine, or torque at the rear wheels?
Do you know why engine torque and rear wheel torque are different from each other?
Do you understand how an engine with low torque and high rpm can actually put more torque to the rear wheels than a high torque/low rpm engine
This guy is missing the point. What moves a truck? Torque!! What determines how FAST you can move it? HP!
Sheesh, the GM guys don't know what they think they know! Quote:"Horsepower alone describes the performance capability of an engine, whether it's accelerating or maintaining a speed against a load or whatever. That's a fact, not an opinion"
WRONG!!
HP only deals with CHANGES, since is the time derivative of work! Thus, only acceleration, not maintaining a speed against a load. If you want to maintain 50mph, you want torque. If you want to accelerate from 50-70, you want HP. The relation between hp and torque so close, it's easy to confuse them. By definition, HP is only present when work is done. Also by definition, it is the RATE at which work is being done. Torque is the work done. So, hp is how quickly you can use torque. So a wheel turning with 100-lf-ft or torque doubles it's "hp" if it doubles its rpm, with NO increase in torque.
Furthermore, it's misleading to say that "more HP HAS to mean more torque". While this is technically true, it more conceptually accurate to say that "more torque HAS to mean more HP" Torque is the independent variable. HP is the DEpendent variable, since it depends on both torque and time (or rpm).
At least this stooge had the part right about the gear reduction. Yes, there is more AVAILABLE torque at peak HP, because you can downshift. What you are doing then is trading the time element of HP for the torque element of HP. Torque can be multiplied, but NOT hp. The time will always be reduced by the same amount that the torque is increased.
If I had a membership to their lame site, I would go out-know-it-all the know-it-all.
As for their dmax vs. gasser dispute, the comparison is only valid if you locked both trucks into 1:1 direct and ran up the hill. The higher hp of the gasser should allow it to pull a load up the hill faster. The higher torque of the dmax should allow is to pull a heavier absolulute load. There is a point (on the scale from light weight to heavy weight) where the gasser would be slower up the hill, as it gets to the point where only the tq of the dmax will move the load.
Letting the trannys gear down skew the whole thing in favor of the HP.
HOHN
There are a number of criteria aside from raw BHP that affect towing performance. Among these are the shape of the torque curve, torque rise, available torque at cruising RPM in top gear, etc. If BHP were all that mattered, why don't we see 16,000 RPM Formula 1 engines that make tons of BHP but zilch for torque in towing applications?
And, yes, I have this ongoing "discussion" with a fellow gearhead with whom I went to college. He is in the "BHP is all that matters/torque is irrelevant" camp - at least until he wants me to tow his loaded race car trailer 500 miles! :rolleyes:
Rusty
Curatchko,
I finally convinced a close friend to buy a new truck. His former ride was a 1998 K3500 GMC c/w 7. 4 litre 454 auto with 4. 56 gears. He had headers, exhaust, K&N filter and reprogrammed the transmission. His new truck is a '03 3500 dually HO 6spd. With the same load he says there is no comparison. His cummins is WAY more powerful and can maintain a faster uphill speed when loaded. The real test will be next week when we head up the Brenda mine hill fully loaded. I will post the results of this semi-accurate test.
Sorry your cummins is a dog. I suspect that it was typical of the '99 auto, 3. 54 stock. A H. O six speed is a different animal. Your friend's '03, is it a S. O. auto? It either is or its broken!
I can't comment on the 8. 1, as I've had no direct experience with it, but no stock 454 is going to keep up to a H. O. 6 spd hauling a load up a hill.
reading ZF's posts, I keep getting a mental picture of two 40,000 lb trailers getting pulled up a 6% grade. One is hooked to a 300 hp cummins in a class 8 tractor and the other is hooked to a 1968 impala with a 300 hp 327. I guess since HP is the only thing that matters, the impala should do fine!:D Before I get flamed, I am aware of the extreme difference in gear ratios and TORQUE multiplication. So throw the 327 in the tractor and it should be fine, right? ... Hello?!
Dave
Graph: I'll try to get my curves into electronic format.
F1: some cars make more the 16000 R's -- gotta love that pnuematic valvetrain!
Hohn: While we're into TQ/HP lessons, what are the reasons for the variations in RWTQ we see for a given power level on the 5. 9? Is it in the dyno, the software, the operator, the driver, the mods, or my bet-the engine itself? And which number would tend to be more accurate?
thread hijack underway:p
Wade i think the different numbers are a mixture of complex variables. The engine is probably a primary reason, but air density, the accuracy of the machine, hell even the fuel quality perhaps could play a minor role.
I have nothing to argue with Hohn about, i have one of those worthless pieces of paper to prove i SHOULD know what HP and torque is, but i understood that concept before i went to school... why? cause it's cool!
Hp is a derivative of work, and is directly effected by the rate. I just wish he would have described it with a little more conviction. I just got the feeling that you don't care about this discussion Hohn ;)
P. S.
On my round trip to Mexico, I just set the cruise control on 72 mph with the camper on, and my truck is an auto c/w 3. 54's, (albeit a 235/460 version).
Dave
Originally posted by DPelletier
Curatchko,
Dave
Yeah his truck is standard output... . I'm not complaining now with the fueling box. There aren't many of anything out there that can run with these things bombed... . I was speaking purely on a stock engine.
I was just surprised at how horrible my truck tows un-fueled... that was the whole point in buying it, was for towing. Thankfully these are easy to hop up.
Chris
