SRadke said:By switching from a 15/16" cylinder to a 1 3/16" cylinder you've added 60% more braking power to your rear brakes.
-Scott
WDixon27 said:that kinda what i was thinking, now is that a good thing?! maybe with a load but how about empty? i hate when the rear end wants it's turn at steering
SRadke said:The rear end should remain behind you, that's no doubt.
One more thing that bothers me is that now you've added 60% more braking power but it also requires 60% more fluid to move the cylinder the same distance. You're master cylinder wasn't designed for this. It is entirely posible that in one pedal stroke your front brakes will come up tight and begin to slow you down before the piston in the rear brakes ever get's out far enough to start pushing. That wouldn't be a good thing.
EBottema said:Hydroboost sounds good but I do have one issue with it. It uses power steering to operate it. If your PS goes out, your brakes wont work that good either. It is another possible leak and puts more wear on the PS pump. It is also a fairly expensive system to fix or replace.
Erik
