KWhitlow said:So you can use 5th while towing. Dodge just tells you to not use overdrive when towing... and believe me, they mean it!
I also think it's a shame to have such a great truck with such a worthless transmission, I really hope Dodge finally gets it right.
Keith
BHolm said:I now have two work trucks with 48re's and my personal truck. Allison may make a lot of great transmissions but the one GM uses, is not one of their best efforts. My 48re's hold OD with big loads. FYI, you do not have to tow out of OD, that is left over from 10 years ago. The 48re will tow 20k plus all day in OD without a problem, the Allison will not, that is firsthand experience talking![]()
BHolm said:"Further proof that all dealers are not created equally I had a 48re fail at 67k. Under warranty they replaced the trans with a new one from DC. They also replaced the radiator, external transmission cooler and I think the lines as well. It is a work truck and tows big all the time. Nobody ever even hinted about what I was doing with the truck as a cause. They did find a code fingering the electrically controlled fan clutch as failing. Never got a check engine, trans temp, or any other indication something was amiss. Mine was in and out of the shop in just 2-3 days. Might be time to go make a stink with the service manager. Unfortunately some places jack you around until you become a PO'ed customer. "
Which is it?
Hold big loads... or fail at 67K?
BHolm said:The fact that GM owns Allison does not preclude them from selling to DC. It makes it unlikely but not impossible. The current Allison 1000 series as used in the GM trucks will simply not hold the torque of the Cummins. It barely does the job on the GM trucks. I think that everyone wants to throw around the Allison name. I've owned two Chevys with Allisons, believe me, it isn't something I would brag about.
Roofer Dave said:My bone stock transmission never gave me any grief. It held 5th gear on the freeway at 70mph with 18,000 lbs hooked to the truck.
I don't doubt the guy posting had issues with his transmission but I know probably 50 guys with Ally trannies and NONE of of us have had any problems.
Cattletrkr said:Now, if Dodge were to ever come out with a 6spd auto, that might change my thinking in a hurry.
