door seal(lackof)
Hard Starting on '01
Amsoil Question
when I am driving in a crosswind, I get a TON of noise thruogh the door seals. If I reach up and pull the top of the door in, I can stop it. Is there an adjustment for this? Top of door out too far?
Thanks in advance.
How Do You Spell Relief?
I had the same problem. It seemed to be leaking air around the window frame - front and top. I have a Quad Cab and adjusted the bottom latch inward about a quarter of an inch and that took care of the noise problem. I know that noise can drive you crazy! I went to Sears and bought a set or torx drivers to adjust it while on a road trip. When the noise was gone it was like taking an aspirin... relief!
I have some wind noise between the drivers door and the Quad Cab door. Can that be adjusted too?? I just dont trust my local Dodge dealer to do it in under a day.
Air Noise
All the air noise I've had was because the rear doors on the Qcab were not completely closed. I've found you must close the rear doors briskly. (slam in Kentucky) Yikes, the pain! With windows closed and all other doors closed, close the front door, and if the rear door moves a little, it isn't completely closed. Hope this helps.
Denny
