Harvey: Yes, but I found that initially my dealer chose to "ignore" the EGR code and focus on cleaning the DPF and Turbo. They'd clear codes, then I'd be back in ~300 miles. Finally, I forced them to resolve the EGR issue. Problem went away.
Edited to add: That was back when you could pull your own codes using the key trick. Dodge in its wisdom has disabled that function on our trucks. Now you need a OBDII scanner or a tuner.
