Dr. Performance
Worthless Cummins Dealer
Hour meter
I read a lot of posts on various aftermarket power enhancement options, however I see very little talk about Dr. Performance systems. I want to know how Dr. P systems are working in the ISB engines. Any engine problems from Dr. P systems? Anyone have warranty problems with Chrysler? I'm curious if Dr. P systems have problems or are causing problems and that's why they are not popular or is it the cost.
My only experience with the Dr. is from listening to other people talk his products so I can't (won’t) say either way, but you will want to e-mail HVAC. I believe he has had some dealings with the Dr. and his opinion is always very honest and based on fact and not hearsay. HVAC has a lot of posts on the 24 valve forum so his e-mail address is readily available.
Good luck to you
Ron
1tuff
Do a search on past threads on the ole Dr. read what they had to say... . JB
99 Quad,Long bed,4x4, SLT,Auto,K&N,Mobil Super Delvac 1300,fuel line up-grade from lift pump to filter and from filter to injection pump, Suncoast coverter,BD valve body and pressure-loc,Mag-Hytec trans pan,Amsoil ATF-4,Auto meter Ultra lite gauges:Boost,EGT,Fuel Pressure,Trans Temp, "true" Jet-Hot Coated 5 inch exhaust from turbo to tail pipe(over the axle)Borla shoot-out muffler,DD stage 3 injectors,4 wire Blue Box,HX-40 16cm2 and ATS exhaust manifold at Jet-Hot for there 2000 series coating(Gray), Valentine 1, EZ-pass
1tuffram,
Welcome to the forum!!! #ad
You ask a good question. This question should be over in the forum for engine and drivetrain.
I will move it on over there and see if you get some more action on this one.
Also, at the top of the page under "Post a topic" and "Reply to a topic" is four words. The one that is research you just click on it and type in key words, like Dr. Performance and you will get everything that has been said on this forum about the topic.
Now a note of caution, most everyone has an opinion and you will see it expressed about everything. You need to pick through it all and decide for yourself. You will really see that for modifications to your Ram, everyone has done it a little different.
Good luck!
