First start with a two wheel drive, do some of the things we do on super stockers, with shocks springs, and Caltrac’s . Leave at a little above a idle, using a progressive nitrous system. You use the brake light as a trigger wire on the controller and set the TPS to 20% throttle. The first channel is “enabled “by the trigger and ramps up 2% at 2 lbs of boost to 10 % at 5 lbs boost. The second channel uses the same solenoids, and is “disabled” by the trigger, and ramps from 10 % at 5 lbs boost to 100% at 30 lbs boost.
This is good for a 1. 62 sixty foot with a M&H drag radial street tire. And the way the power is rolled on doesn’t break parts, “yet “
