draining automatic trans
I HAVE SEEN THE 4DR 2003 RAMS!!!!!!!!!!!
How to remove pinstriping
Is there any way to do a complete drain on my 1997 2500 4x4?I want to fill it with synthetic ,but Iwant to do the whole thing not just the pan.
If you have a stock TC there is now way to completely get all the ATF OUT , you can remove up to 12 quarts of oil. After you remove the pan loosen off the 10 valve body bolts (7/16" heads)approx 4 turns each. This will allow you to drain 1/2 the oil that is in the TC. Most synthetic oils are mixable with regular ATF , most after market TC's come with a drain plug so you can change most of the oil.
