Drilling Frame Rail
DTT converters on sale now...
"Behold the Power of Cheese"
I am mounting an air tank and wanting to mount it directly to the frame. Would require 4 new holes. Would these cause any problems with the strength of the frame?
If they are <1/2", I see no reason why they would casue any problems. I've drilled holes in the bottom and sides for various things, and never had any problems. I would drill the holes in a flat side, i. e. not on the corner of the frame.
DP
Minimum clearence or bolts!
I'm with DP, here! I would add that the holes should have minimum clearence, not way oversized for a sloppy fit with the bolts. If you match drill the bracket and frame together with a 1/2" bit for 1/2" bolts. IMHO that would be perfect! Bolts can be a little undersized by a few thousands and sometimes a 1/2" drill bit cuts a . 502" hole. There is all the clearence you need. I mounted the class-III hitch with 1/2" bolts and shoulder nuts on, match drilled through, the bottom flange of my 1st Gen Frame. I have had no issues in 17+years. A large clearence hole allows the two pieces, that are bolted, to act as a shear on the bolt through vibration or a catastrophic incident like a crash.
