2nd Gen Non-Engine/Transmission Driver Headlight gremlin
Engine/Transmission (1998.5 - 2002) Hats Off!!!
Hi guys - When I turn on the headlights first time that day, the drive side never comes on.
I give a very light tap and it comes on and stays on, even if I turn it off for a while.
Next day, same thing. . needs a tap to turn on. (wish the wife was like that :D)
I tried new bulb and jiggled the harness, and that works for a while, but eventually it needs that little rap.
Any ideas?
Tapping equals bad connection you got a broken wire or dirty connection
Are you tapping on the light or the switch?
I have seen a broken filament act the same way. Have you checked to see if the bulb is OK?
edit: went back and re-read that you have changed the blub... so i would agree connection or wire broken but making contact
Mine did that. At first I thought it was a bad ground but ended up being the socket that plugs on the bulb.
Scott
