Engine/Transmission (1994 - 1998) dropping out of lockup
Engine/Transmission (1994 - 1998) What is a '97 engine worth?
Engine/Transmission (1998.5 - 2002) Overflow valve
i have a 98 12valve 47re trans i have cleaned the throttle position sensor i think it helped for a couple of days but now it locks up then with in 1 to two seconds it unlocks but if i give it more throttle it stays locked,is it my throttle position sensor or my alternator giving it noise? do i need to put in a filter?how do i check so i know? rod
Check your TPS by putting a meter on it and manually opening the throttle while watching the voltage. The rise should be smooth across the travel of the TPS. If you see any spikes, drops, flat spots, jitters, etc, the TPS is worn internally.
If that looks good try wrapping tinfoil around the wire the runs from the passenger side battery across or close to the alternator. If that works its noise in the PCM lockup circuit that is the issue.
the bd filter did the trick for a awhile i was having a noise issue but it came back after about two weeks a little different so i had two problems noise and tp sensor i installed one of these and cured it! thanks guys!
1st/2nd Generation Dodge OverDrive Kit *91. 5-98 12v* [DNR] - $37. 99 : Zen Cart!, The Art of E-commerce
