cold weather
Hello Ken and all the others that are dealing with the cold weather.
Ken the mix you are running winter blend at 100% no diesel fuel will plug filters at 32 degrees this was tested by Amalgamated inc.
A mix of this same fuel at a b-20 blend 20% your fuel and 80% diesel started to plug filters at -18tested at the same lab.
They have a new product that is good for biodiesel and I think they also said it works good in Vegetable oil also I got some info on it but I just dont have any money to try it. THEY HAD SOME OF THE BLEND I MAKE FOR TESTING.
Did I read that you are mixing at 50/50 and if so you should be good with the weather you are going to get but if you want just top off the tanks with diesel fuel and you should be good to go.
If you have problems remember gasoline will unjell the fuel fast your truck has a 34 gallon tank on it full of fuel 2 to 3 gallons of gasoline and 1 to 2 hrs of it in the tank will get the truck running.
I was up snowmobiling at Arrowhead lodge in the Big Horn Mountains two weeks ago the outside temp was -21 and the wind was blowing about 20 to 30 mph THIS WAS AT 10:00 IN THE AM the temp was a lot colder when the sun was down.
No I did not have my truck but there was a new ford truck that was jelled up and they ran the batteries down trying to get it running. the manager of the lodge got his truck started (I think it was pluged in )and towed him up from the lower lot and got the truck pluged in and a charger on the truck.
They were looking for an idea to unjell the fuel and the person I was with told them gasoline but he was not sure of how much to use they came out and talked to me and I told them with the amount of fuel in the truck they should add 1. 5 gallons of gas and let it sit for around one hr. either that or about a 400. 00 +tow bill down the mountain.
They did what we told them to to.
The truck started up and ran just fine after 1 hr the outside temp at this point was -10 and the heater in the block could not keep up with the out side temp being that cold. The owner of the truck was gone by the time we got back but he was really happy to get the truck running and not have to have it towed down to the bottom of the hill to warm up . this truck was an 2008 ford and what I also told him was to top off the tank as soon as he could with diesel.
hope this helps you
that cold you are getting just missed us but we have had colder for about two weeks and are really happy we did not get it.
I did get a small batch of fuel in my truck running a 75/25 blend right now I have about 1500 gallons of oil that I need to make in to fuel should be 50 degrees here by friday
cj hall
hope this helps you
cj hall
