does the track bar help that much ??do i need both... . my steering is drivin me nuts... thanks for the replies
mercel
mercel
adjustable track bar if you have a leveling kit. My axles are not centered since mine is not adjustable. .
Only difference is I run a DSS and a DT trackbar because it is adjustable so I can center my axle being it has a leveling kit.
going around corners i end up oversteering and have to compensate every time
track bar is def bad... . i think it will be my 5th one... . truck also darts from side to side... going around corners i end up oversteering and have to compensate every time ... i am very used to it at this point but ti NEEDS to be fixed
Has anyone added the DSS and 3rd gen track bar set up with a snow plow mount? I would like to do this also but I have a Fisher snow plow with the minute mount on my truck and from the install pictures on his web site I'm not sure it will work. Any ideas?
