Originally posted by RADdodge
One thing I will say, when you start you truck and put it in gear, do you have to give it some pedal to get it moving? Not with Bill's TC! It's about 7-8 mph once you let off the brake!
With my 93% TC I travel @ 11-12. 5 mph on the flat section of gravel/dirt road leading to my place.....
at idle! The efficiency of the 93% TC makes changing directions (i. e. , from any forward gear to reverse or vice versa), as well as going into Park
interesting. I modified my parking procedure to eliminate the
clunk (which comes with the extreme efficiency of this TC)... I now place the gearshift selector in Neutral, turn off the engine (when at or below 300 deg. F. EGT
) and then place the gearshift selector in Park.
The 93% TC is a bit harsher than the 91% TC although, as I stated before, it's my favorite. That said, the 91% model has just about the perfect balance of efficiency and driveability traits. I have not driven the DTT 89% model. At the time I had my DTT enhancements done (1-13-01) there were only two customers with the 89% TC however, the popularity of this particular converter has really taken off!
If you are in doubt as to which TC is best suited for your driving style, power enhancements and suspension particulars (i. e. , tire size/axle ratio) or its intended purpose (i. e. , hauling/towing, drag racing/sled pulling, general grocery getter or a combination of the preceding), Bill or Stefan can help you decide which would work best for you... just give them a call! Remember, DTT is not an off-the-rack outfit, they tailor each VB to suit your "profile"... a profile that has been compiled on (hopefully accurate) information provided to them by
you, the customer.
Also check out DTT's website at:
www.dieseltrans.com
