Thats interesting news. Good news if what they are using now is even better - Bad news if not and they have to build a track record all over again.flattracker said:DTT and their torque convertor supplier had a parting of the ways this winter
ChrisKringle said:Well I just bought a TCS torque converter for $495! Half the price of DTT! I got and 89%, part #4889. Confirmed, was DTT's supplier of converters 'till recently. Even though ATS has the triple disk clutch area, I'm thinking I might be happier with TCS's stator drive charactersistics. From what I've read, ATS just has no fluid coupling.
So now I've got some extra change, should I do the billet output? Inputs a given.
Flexplate... , was told billet units do not flex, FLEX plates should, so billet units create additional stress to other componentry.
Any opinions?
bchesley said:If I can buy a TCS converter for half the price of a DTT and they are the same thing, than why would any one buy a DTT. That just sounds funny. Are people paying the extra bills for the name???? I was about to order a DTT but would love to clarify this first!
Brad
flattracker said:TCS also built DTT's billet shafts
I know for a fact this hasn't been the case for quite some time. I. E. (Intellegent Engineering) has been making these for DTT.
Bill is without doubt one of the best transmission techs in the world, and their customer service is second to none, But he is also known for getting hot in a hurry and as it was explained to me this turned into a real finger pointing screaming match before the split.
If you knew the why's of the split you'd understand why there might have been some finger pointing.
I have used both TCS and DTT convertors in the past and had excellant results with both.
Where they diesel converters from TCS? If it was a diesel converter how long ago was it?
On another post recently someone posted that DTT'S convertors were backordered and they had recommended ATS as having a good convertor that tells you right there how far this has deterioted. I guess the transmission wars continue unabated.
Any opinions?
I am sorry but I read that over several times and still don't understand what you are saying??flattracker said:the TCS convertors were diesel convertors one with the old milled aluminum stator in a stock truck , a tight convertor in a two wheel drive truck that has to back a trailer uphill is not a good match thats why the looser convertor the other a steel stator in a 48re post split, an 89h with an DTT update kit in the trans works great.
Got Smoke? said:What about Dave Georend Trannies! Lifetime Warrenty on the Convertor & 100K warrenty on the valve body (if I'm not mistaken) :-{} :-laf
