..... love that DTT 93!
(Piers type grin)
The efficiency of the TC is measured in different ways by different vendors. BD states their TC is 95% efficient however, the DTT 93% TC is actually quite a bit more efficient. In fact, Bill Kondolay tells me their steel stator TCs put 40% more power to the ground than ANY OTHER TC on the market. I have driven one of BD's "95%" TCs and believe me, there is a big efficiency difference between my 93% TC and their (lesser) counterpart. Nowell (HVAC) has a special DTT TC that is about 94. 5% efficient. Even with the kind of power he is putting to the road, the extreme efficiency of his TC tries to stall the engine (at idle).
The best thing to do would be to give Bill Kondolay of DTT a call on his tech. line at: (604) 504-4002 and discuss this and other issues you may have concerning TCs etc. You can also post your questions on the DTT website BB (
www.dieseltrans.com ).
John Treibel
'98. 5 2500 QC 4x4 Sport, Glasstite Vision II, 285 BFG A/Ts on M/T Challengers, Warn 4X Boards, Mopar fender flares & tow hooks, NW Custom s/s-rubber mud flaps and accs. , Mag-Hytec diff. cover & DD trans. pan, Edelbrock IAS shocks, Reese Titan V hitch, SPA gauges (3), Dynamat, '00 Sport grille and headlights/PIAA Super White bulbs, PIAA Dual Sport 900 aux. lights, BD exh. brake, Amsoil Dual Remote Bypass w. trick billet block adapter and Aeroquip Teflon-s/s hoses, Optima Yellow Tops, DD3s and DD TTPM, Aeroquip AQP s/s fuel hoses, tricked out Cummins valve cover, tricked out Banks High-Ram intake manifold and 14 cm2 turbine housing w/Big Head wastegate actuator, ATS 3-piece exh. man. , Banks 4" dia. s/s exh. sys. , DTT 93% TC, DTT custom tuned VB, BD modified trans. front pump (enhanced by DTT), Air Bulldog induction hood (with NACA ducts), plus MANY other trick modifications
NRA Life (Patron) member
[This message has been edited by John (edited 05-09-2001). ]
