Joe,
Based on the description provided by PSM, I believe it is. If not, the characteristics of the dura-flex 9025 meets/exceeds the requirements to be used in a cold air intake system.
If I remember correctly, the 9025 has a temperature range of -60*F to 275*F (sustained) with capability to withstand 300*F (momentary). Also, it resists solvents, oils, etc. Too, it is steel reinforced thermoplastic duct and very flexible.
I made and installed the cold air intake system (similar to PSM), and added an Amsoil EaA replacement air filter. The filter minder doesn't move anymore, which tells me I no longer have a restriction (providing all the air the turbo compressor needs).
I don't have a pyrometer, so I'm not sure what impact this setup had to cylinder EGTs.
Dwayne
