Duralt Fuel additive 15% discount and results/comments/questions
Gauge installation disaster
gauge lights
duralt
Well I tried the Djralt in my 93 Harley. I went from Pa to Fla and I didn't get anything more from the Duralt. MPG going to Fla was 36. Coming back I didn't use the Duralt and MPG was 36.
I put it in my 97 Jeep Wrangler and I am getting 18. 7 with Duralt. Without Duralt the Jeep gets 17. 9 so theres a little increase.
My truck, I only made one round trip to Harrisburg, (320 miles) since I put the Duralt in it. MPG with Duralt was 20. 5. Before using Duralt MPG 19. 2 All highway and empty. Oh one more thing, I have been using Power Soure from Wallyworld and I used it with the Duralt. In the future I will use just the Duralt.
I've used one tank of it... forgot this last time I filled up, was in a hurry to get back to work on the retaining wall. I don't know if now I'm seeing results or just highway miles... but seems to be higher mileage, but then again, I've been hauling some weight too which always helps a new truck... plan on dumping in the 2-5 gallon jugs tonight and dump in the dulralt too...
duralt
I have tried Duralt on my gassers 2 different Toyotas for a total of 7 tank fulls and the results are a biiiggg ... . ZERO. Both Toyotas are very consistent with the mileage with or without Duralt.
I will not run additives in the diesel until it breaks in. I have had problems with running additives pre-breakin on other vehicles. If there is no improvements with the diesel, I will not buy it again and will ask if they are willing to refund for the unused amount.
Chris
Nada....
Third tank on the ram and zilch. I even babied it trying to get hers up, no go. Second tank on the Dakota and no results there either. Will keep using it just for the lubricating value now that I have it.
Garrett
I've run 1800 gallons thru our two 3500's, been keeping close watch and no increase in mileage. None...
In my PT Cruiser I've gained, went from 26 to 28 mpg since using it. From what I've seen it works better in the gassers.
Just what I've had for results,
DW
Chipstien,
We truck cattle around to auction barns and slaughter houses, yea we put on some miles. One of our trucks is a 6 speed and one's an auto. The auto doesn't get very good mileage anyways, but towing it's horrible. Averages around 11 mpg towing, but the loads usually weighs between 16 and 20K.
I think I've given Duralt a fair test.
DW
Well I just threw my hat into the ring. I usually dont go for "snake Oils" but with diesel at $1. 69 riight now I would take a eight to ten percent increase in milage. :D I even fell for the buy three and get one free. I probabley should have gone with the $10. 00 option but my history is always been jump in with both feet!
