Joe I dont disagree with what you stated, and my definition of "meager pronouncments" would be "laymens terms". the principle that the dynojet is based on is called Rotational Inertia. and it, is based on the fact, that at any given time a computers software can precisely calculate using pure maths, the power. by the simple input of the drum speed and engine RPM's.
but you still kinda danced around the fact that the dyno jet because it cant load the engine up correctly. it is friction control only, and that is not exacting and cannot be duplicated. and/or the operators ability to do so, result in the readings being scewed.
the operators have to carefully time the run and know when to time the run, thus making outcomes, not consistent across different machines, trucks and operators. it also helps to have an understanding of the vehicle that is on it and its behavioral habits.
IE. "the sweet spot"
this is why if you compare a mustang dyno (which can simulate different loads through an eddy current system, which is easily duplicated, after the dyno is calibrated) and Dyno Jet (drum weighting is the only fluctuation) the mustang can produce a more easily obtained continuity. between machines and operators. if the load is set the same, and the truck is the same, the second guessing of where the sweet spot is, is eliminated as long as the operator selects the same gear and starting point(RPM). the outcome should be the most the engine is capable of, using the "brake", and can be measured at any point in the run, or held for infinity if desired. or the operator can pull the engine down and let it go and more accurately measure torque and HP. Not just look at what it was doing at that moment in time of the run, like a dyno jet.
just my 2 cents worth. I'm sure you will disagree, but thats what makes up our little world we live in.
