Engine/Transmission (1994 - 1998) Dyno'd Truck
HEMI®Dart
'94, 180,000 miles. 175 HP pump. Straight #2 diesel only. Twin Dyno jet 248
run 1:
447. 36 HP 941. 27 Torque HP in @ 2300
run 2:
448. 09 HP 942. 69 torque T in @ 2600
Max boost about 48 p. s. i
Max egt?
TST #0 plate
D. D 140HP overstock injectors
I. I Silver 62/14
ATS Pulse exhaust manifold
4" turbo back
191 Delivery vlaves
3000 rpm governor springs
Icebox cold air intake
Fluidampr.
Southbend con-0
does the torque seems low?
not really, mine is right around there with about 45 PSI of boost... before you crank it up some more maybe you want to inquire on a head gasket and head studs... I just had to do mine cause of the boost issue... . and have you done anything with the transmission... . I also had to replace mine... I put an ATS transmission with stage 5 billet torque converter, billet input and out put shafts, torque lock up commander and valve body's with the deep pan that holds 15 qts. Just wondering you dont want to let the truck let you down!
ATS transmission-7500 dollars
New Head-550 dollars
ARP Head Studs-460 dollars
Hybrid Turbo-Free
No fuel Plate
Watercraft Injectors-on truck when bought
45 PSI
and the price to have a little fun-Expensive!
