I have an early 04 which is mostly stock. I bought it knowing it had a hard start issue. Has 173K on it but engine was replaced at 113K. Sometimes it will start fine, sometimes it cranks awhile and starts, sometimes it won/t start at all. I hooked fuel pressure gauge on inlet of CP3 and have 7-10 psi at all times lift pump is running. Hooked scan tool up to truck and rail pressure reads 4800-5500 while idling. When it won't start or cranks before starting rail pressure seems low like around 800 to 1000, as soon as it gets to 1600 it fires right up. I unhooked the FCA and it shoots to 26K, and I tapped a cap into the Rail pressure relief valve and it still operates the same. Where should I start looking for my problem? I have no smoke and it seems to idle and drive really good. only problem is the hard start or no start.
