2nd Gen Non-Engine/Transmission Easy way to remove driver seat cover?
Engine/Transmission (1994 - 1998) Truck running cold...thermostat
Engine/Transmission (1998.5 - 2002) Fuel Filter Canister Drain Valve
Hi. :) I want to get my truck's driver seat repaired due to the damage on the left side so common on these trucks. Is there an easy way to remove the seat bottom? I'm having my wife sew in a new piece using the old as a template. I'll probably use strong marine vinyl in a color close to the right side. I'm tired of having a nice looking truck with foam padding hanging out when you open the door:mad:. Thanks, Herb
Thanks a lot guys! This is why I'm a TDR member since 1999! Cheap price for the help here. Now to get some vinyl! Herb
no problem,
dont forget to add a thin carpet under your foam and where those support wires are visisble from the bottom, it will support better and stop them from cutting the foam.
also if all your wires are broke like most are... on one seat I used HD HVAC ductwork pull ties in place of the wire for support, worked slick and I could set the tension I wanted real easy.
peace, B.
