Engine/Transmission (1994 - 1998) eBay s300g
Engine/Transmission (1998.5 - 2002) Selecting a Tuner
Engine/Transmission (1994 - 1998) P-pump for dummies???
I put in my 191's this weekend and I am really HOT. 1600* is easy to hit on hard acceleration. I have now decided that a hybrid will not probably cut it. Does anybody know anything about the s300g's that are on ebay? Are they a 62/12? They go for pretty cheap, usually around $800 which is a lot less than those from HTT. Any input would be appreciated. Also with my setup with 191's now, is a 62/12 about right?
TIA
jamie
I think it all depends on which S300 you go with. there are at least 4 different versions of the 300g from schwitzer, 2 different turbines as well as 2 different comp wheels. The largest being a 61mm 49 trim wheel.
I think most of the cheaper ones are 57mm or so on the inducer.
If I remember right, they flow like 62 lbs/min or so. That could be off though, just going of memory when I was looking into one.
174430, this part number is the same basic turbo as BD's super B. It has the "extended tip comp wheel".
--Jeff
