Engine/Transmission (1998.5 - 2002) Edge Comp Questions
I just bought an Edge Comp. Don't worry I have gauges, a BD aux pump, and fuel pressure of 25 delivered to the injector pump. How do I change the settings of the comp? What are the best setting for a HO with stock injectors (I don't mind if it smokes, actually I would enjoy that)? If I do get new injectors, which ones work best with an HO/comp combo? If I do get the injectors, should I consider a clutch also? Thanks in advance! :)
To change setting hold the far left button down the lights will flash go left or right buttons for smoke levels. You have 5 power levels and each have 5 smoke levels
F1 diesel makes very nice injectors, South Bend clutch maybe a MU 1947 con OFE.
In mine if I am running around without a trailer it stays on on 5x5. If I am loaded it is either off or on 1x1. With the cruise set at 70 mileage is not any worse at 5x5 than it is on 1x1 or off. stock clutch with over 100k and it hasnt slipped with the comp yet. but when it goes i'll be going with a south bend ofe
