I just installed my Edge EZ and took it for a test drive. I can feel the new power, but not as much as I expected. I also installed the boost elbow and can get about 24 LBS empty. I got home and wanted to check that the setting was in the most agresive position. I pulled the cover to look at the 6 pins. ( 3 sets of 2) and found that the two left sets have the small plastic jumpers installed. The instructions only show one jumper intalled at a time and indicated it would be on the right hand pin position(most aggressive). I got the box from smokindeisel and they are closed for the week-end. I chose their box that has one timing only position and two timing plus fueling positions. I only got the regular EZ instrucions with the kit that indicates that it has 3 timing plus fueling positions and the jumper should be on the right hand pins when new. Any help would be appreciated!!!!
