I installed my Edge Juice w/Attitude today. I took about 45 minutes to do the install. Get the ladder and tools out, etc. I took my time and made sure I followed the instructions exactly. Very simple install. Started up and everything exactly as the manual said. I had no codes or any problems. Tie wrapped/velcroed everything and was done. I did not install the pyro. I will use my pyro gauge to monitor this for now. My dealer has already done injector replacement with my gauges installed. So I can remove the Juice and Attitude in about 15-20 minutes and look just like I did before.
Tested all 5 levels a little, too much traffic on the road to do real performance testing on all levels.
Level 1 Mileage = Smooth running, maybe a little more responsive. I hope this will really improve mpg.
Level 2 Tow = Smooth with a little more power at mid range, dont have anything to tow, so not sure if I need this level.
Level 3 Drive = I like this level, first time I have really seen any BLACK smoke. Just a good puff when WOT from stop. Feels good, definitely much quicker acceleration.
Level 4 Race = The puff of BLACK smoke got much bigger and the 315s are very easy to break loose. Might be my normal setting.
Level 5 Extreme = I gotta find a ricer to smoke. Ok this setting does make the 48RE slip a little and on asfault I am sure I could keep the 315s spinning until I let off.
I nailed it from dead stop, no power brake. From stop to about 85 at all levels. It got there quicker on each level(Of Course). EGTs under 1200 on level 1,2 and 3. EGTs did not get over 1275 on level 4 and got close to 1300 on level 5. Boost never got over 33psi.
I will play as much as possible in the next couple of weeks. Going the track on the 27th, maybe next Sunday and get some real world numbers to compare.
Local group planning a Dyno Day soon and I will find out the actual hp/torque numbers then.
For now all I can do is:
