Mad Bomber said:You'll love the EDM's DON'T ditch the E-Z the combo's great. Clay had troubles partly because it's a auto and you've got the 6er.
Azhuskcarr said:Just out of curiosity, where do you get Don's EDM's???
Sixpack said:Yes I would have to agree but still I'm just a bit concerned in regards to towing the 5r (heat).
Anyone know what these sticks produce hp wise in a ETH?![]()
BUFF said:I just installed the 1. 5's and already have an EZ on my auto equipped truck. What problems did Clay have??
Mad Bomber said:Phil, when my pump wire came loose on my truck I belive I was at 360 on the B-D dyno. With a 6 speeder you can reduce the heat by just down shifting and turn up the revs. Towing my TT over the mountain the box is on 1X5 and NO HEAT ISSUES AT ALL. Do you have a stock turbo still? You can also turn the E-Z down to 1X1 or even disconect the cummins plug if needed to become just a fooler.
Mad Bomber said:He had the 3. 5 rear end and bigger tires :{ that does NOT work well
M Evan said:I replace my HY 35/9 turbo for HX35/12.
M Evan said:Just curious, what problem he had ? I'm planing to install EDM 1. 5 and I do have Power Edge EZ. I replace 265 original tires with 305 tires size. Now I run 275's and EZ on 10 psi boost fuelling position and don't have any problem, my towing is a 10K toy hauler trailer. And I do have 3. 55 rear end and automatic trans. I replace my HY 35/9 turbo for HX35/12. Do I'm looking for some trouble, if I put EDM 1. 5 in ?
BUFF said:I left my EZ on the advanced setting... . have not noticed any problems, although I have not towed with it yet.
