EGR Brake installation
Which Fender Flares?
Twin Turbo Question
Finally got the oppourtunity last night with the help of a neighbor to install the the set of EGR Kevlar pads and SS front brake lines last night. Glenn is a good guy- since he is close enough I went out and picked them up in person. :D
I didn't have the $$$ to go with the crossdrilled/slotted rotors, which are in the nighborhood of three bills a piece:--) :{ And still have some life left on my OEMs. The install was real straightforward and the pads seem to have a firmer earlier grab. I was using NAPA pads before, nothing special. The steel lines to the front do have some room for improvement, IMHO. There is no place to attach the ABS sensor sending wires as there is with the OEM lines, and they seem to be a tad shorter in length too. On the drivers side there is a protective spring for abrasion , but nothing on the passenger side, where it rubs in the same area, against the shock. Not much mind you, but enough that I'm going to put something there to help it out. I just tywraped the ABS sending wire for now, maybe I'll come up with a better solution soon. Anyone else come accross these concerns??
I also bought the rear drum kit, including the new spring kit, shoes, and adjusters (and SS line of course) but didn't have a chance yet to install them. Maybe tomorrow night. Since I know my rears are WAY:rolleyes: out of adjustment, I can't really say how much better the braking ability is until they are done... ... ... ... . I'll let you know.
Kev
I did not have a problem with the ABS sensors. I just used the original clips that were around the rubber lines. They seem to work fine and would not incur the rubbing of the tir wraps.
As soon as I have problem with my calibers I will give Glenn a shout. I plan to upgrade as things wear out.
:confused: Unless I'm missing something here, on my OEM lines at least, the rubber fittings you speak of are pressed onto the line before the fittings were put on and I see no way of getting them off let alone putting them onto the SS lines. Are yours slotted or did I just not see how mine were on??
Kev
Maybe they are different for you year.
Mine were snap on and all it took was a little careful prying with a small screwdriver to get them open and moved to the new lines. You might want to give them a close inspect to see if you can do the same. Good luck!
