Hi all,
Truck specs: 97 3500 4wd dually 3. 54 gears bhaf 370 injectors factory turbo
Dilema: Truck has no power when towing light loads, and egt seem high running easily up to 1250 pre turbo on little hills trying to maintain 70 mph. Empty they also run 750- 800 pre turbo on level ground. Had turbo waistgate disabled and could see around 34 lbs of boost. I hooked it back up and could still see 26 lbs of boost, which seems in line with the factory setting, so I think that fuel supply is not my problem in the power department, nor are boost leaks. I have been thinking that my timing had slipped from it's factory setting, for quite along time, but just recently after I start it and let it idle for a few minutes and then tap the throttle I get large quantities of white and blue smoke. Help Please.
Texram
Texram
