It's best to bypass the mechanical lift pump completely or do what some have been doing, by routing the electric pump to dirty side of the fuel filter housing by way of a tapped banjo bolt.
The mechanical pump is only gonna open/close/pump so fast, so by adding pressure/volume to the inlet ain't doing no good to the injection pump, just supplying p/v to the stock lift pump.
There is reference to min. /max. fuel pressure, you don't want to starve the VE as it is lubricated with the fuel and the problem with too much pressure is seal failure and fuel in the crankcase oil. Volume in liters/min. is referenced also. The 1989 spec is 191. 5 liters/min. @ 1800 rpm.
HTML:191. 5 liters/min. @ 1800 rpm
This can't be correct. That converts to roughly 50 gal/minute . . no way.
Perhaps a misplaced decimal?![]()
