I have a failure that has to be fixed to get an inspection sticker by next week. The problems all occur simultaneously as follows:
While driving, usually after being in motion from . 1 to 10 miles, depending on how rough the road is:
1. The brake light and ABS light comes on
2. The speedometer goes erratic, bouncing around randomly. The faster I go, the wider the swing of the needle. Will bounce around between 50 and 70 when going 70 (using GPS to determine true speed).
3. The cruise control fluctuates in sync with the odometer movement. i. e. The needle drops, kicks in the accellerator, backs off when needle bounces back to 70.
Having changed out the ABS sensor on the rear axle a couple of years ago, and before realizing a connection between this and the speedometer, I replaced the sensor again, but nothing changed.
Where is there a harness connector that would contain these sets of wires that is probably loose and bouncing around? I plan to get under the truck and jiggle wires with the key on and see if I can recreate the problem, but would be faster if someone has solved this problem before.
One other side note, last week when in Amarillo during the snow and ice storm, I drove for a while then parked over night and had ice hanging from under the truck. Leaving the city, I drove about 100 miles or so before the problem showed up again. It was after I was in a warmer area above freezing. I am guessing the loose wires got frozen in ice and were not moving until the ice melted.
Any one know about this problem?
'98 24V 4x4 5 speed 4 door short bed 2500 Ram with goose neck hitch and ABS only on the rear, 111,000 miles.
