Ok, Ive posted before on some of these topics, today I am at my wits end. In the past year, I have replaced the transmission temp sending unit, TPS, added the ATS noise filter (to solve the OD lock/unlock problem) and eventually put in a 1000 ohm resistor in the temp sending units place. Now I have spent weeks working on the no charge problem that developed in early Dec. After testing the alternator, it was weak (not shot), I replaced it any way. That didn't solve the problem. I also lost the tach and speedo. Next went in a new PCM, when I first started the truck it was charging a little over 14 V, tach was functional and all looked good. After letting the truck warm up a few minutes, when I put it in gear the tach went dead. Fed up I ordered and waited for a new crank sensor, installed it and started the truck. Charging appeared normal, tach worked, until I put it in reverse to back out of my drive way. Tach went dead, charging now appears low like it did when this first started (8 V or so) and I am at a complete loss as to where to go next. All the grounds were scrubbed clean last fall (during transmission shifting problem)and I am currently rather angry and very frustrated. Any and all help is greatly appreciated.
Matt
Matt
