Electronic Boost Builder
Viper remote start
AC Control Issue
I have an 03 Dodge and found this item called electronic boost builder. I'm wondering what it all does and how people like it. Is this something someone can use with the factory turbo and waste gate or is it best to upgrade to a different waste gate?
Thanks.
AH64ID Thanks for the response. I don't know much about the after market waste gate that a person can install on the turbo is it a good thing to add?
It should be pretty easy to install. You put it in, and go drive WOT for a few runs, see that your make boost is. I would set it around 30-32. If you want less turn the screw CCW, more CW.
I have a boost fooler on my truck and I noticed that my EGTs remain cooler. I believe it intercepts the signal to the computer so it holds the electronic wastegate closed longer giving you about 8 to 10 psi more boost before the wastegate opens. I like mine... .
The boost elbow should have been included with the Edge/Juice, my EZ did. Mine is not adjustable however, it is preset to 30/32 psi. What is your max boost?
Nick
