Electronic Throttle Control Light (ETC)
TFP door handles
6.7 Fuel MPG
OK! the five Second rule.
After repeated attempts I finally got it to read.
P2262, P245A.
Thanks for the help!
Glad that worked for you. Interesting set of codes there. Turbo boost pressure not detected and the same EGR code my truck threw on the first long trip with the truck. My confidence level in this vehicle is dropping...
First, the turbo is not turning at this point, therefore, the reading is bogus.
Second, I already know there is a faulty EGR valve as it is on oder.
Third, I have every confidence in this truck. My only issue is will all the problems be sorted out within the warranty period. The truck runs great except for the polution equipment sensors. My suspision is the heat due to the excessive active regeneration cycles is/has fryed the sensors. I am having guages installed to monitor this situation more closely.
