EMS hub install, IN COLOR!
HD radio
Tire height for speedo correction
I just installed the Dynatrac hubs and the question in general is - after about 2000 miles on them the hubs are running hot. By hot I mean hot to the touch, not so hot that you have to remove your hand. Has anyone experienced this?
The bearings might be a little tight but your brakes will heat the hubs up quite a bit, even in normal driving.
Has anyone put the EMS or the dynatrack hubs on a dually, and if you have do you have any picks?
I believe with the EMS Dually kit they run a dual flanged hub. one for the brakes, and one for the wheel.
I do not believe there is a kit from Dynatrac for the dually's yet. The factory hub spacers won't fit over the hubs.
