Engine/Transmission (1998.5 - 2002) enclosure for pusher pump
Engine/Transmission (1994 - 1998) Engine shutting down
Engine/Transmission (1994 - 1998) Having problems with 370's and 191's
Here's what I use:
The electric sender for my Westach fuel PSI guage is seen, and the relay box mounted to the firewall is keyed by voltage taken from the stock LP - then a separate 12 volt line runs thru the relay to operate the added pusher pump down at the fuel tank - thus, the added pump operates exactly like the stock LP, but on it's own 12 volt line...
