Well Got my baby back today and it runs great!!
Got a new clutch in it and new bearings for it and they put Redline MTL Fluid back in the transmission... . The brand of the clutch is LUK It is a ferous and friction combination... . seems to do good... Funny thing is th back side of my South bent clutch said Luk as well... . ???... Should do OK... . will see on the trailer... . I had the clutch hang up due to a Pilot bearing go out..... So far this clutch feels real nice. .
But first a little history on my problem... .
My Truck has almost 72,000 miles on it and the 53 crack happened... . I tried the Lock-n-stitch shown here
I added a little JB Weld to try to strengthen it... . didn't work
I was told by cliffman that he did his repair, towed his trailer, and it made another crack 3" away from the other repair... . so, I got another Block, A Mexican block (suposed to be thicker)... from another member,... . had to have it bored . 020 over because someone honed it . 003 too big to be standard. . So add $1000 for new pistons..... Then built and installed the motor..... I wasn't around for the job step by step as I am an hour away and I drive truck for a week at a time... But I have some interresting pictures of my engine and the cross section of the thin area where my Lock N stitch repair was...
This is a very bad cel phone pic but you see where I tried some more JB Weld and a stiffener... . didn't work...
Pic of my cylinders..... These are in very clean condition... I was even able to see the hone marks from the factory on the walls. I have almost 400 Hp and tow a 15K 5th... . I hardly see any abuse of heat at all...
So, all of the engine was perfect, ran great, had no problem... ... except for the crack... ... . Geez!
The pic shows the the grinding of a piece of metal out of the block for a souvenier... now, see the cross of the grinding... the vertical one shows thick metal above and below the curved area... . now look at the horizontal one, see where it brocke through very soon near the intersection of the cross? Thats the thin area...
This is going to be the best 53 crack picture yet to show what is the problem... . The thin area is where the curved area is, and where I did the Lock n stitch thing... . Amazing huh?
Here is my souvenier I had ground out of the block... this shows the outside ... you can see the Ls pins...
This is the inside of the block... . The pins that was of the LS. . were not totally overlapped inside so that is why it leaked but still the weak block had to go...
