Engine lope on fast idle
Shop in Casa Grande,AZ
#4 injector line
Now i am a little worried....mine lopes also...not severly and its really cold here in Newfoundland these days. Hope its not injectors,i really can't afford that right now.
Duhhhhhh....how do you turn up the idle with cruise...I tried it like i would on a tractor (truck) but it doesnt seem to work
Cruise on, press "Set". Then you can vary it using the "Accel" to increse and "Coast" to decrease.
Mine is in storage right now (since November so memory is a mite fuzzy) and I may not have the wording on the buttons exactly correct.
If this is on the '06 in your signature I am quite sure that the feature was enabled from the factory. If you can't get it to work you may to swing into the dealer and have it activated.
Mike.
Thank you Mr Wilson....i will try again tomorrow.
Mike.
My "06 has been loping since as long as I can remember. It has always been when it is cold(below freezing) outside. I too have an Edge, but it is set at stock setting. The feature I use with it is the turbo cool down timer. I've never been able to adjust the fast idle, guess I have to try the stealership to activate that feature. My son's '03 also lopes, and he has no added enhancements.
My 06 in sig will lope slightly at 5 to 20 degrees when at 1000 rpm, just a slight lope at that. Never thought much about it. Runs great otherwise. All stock - 75k on odo.
Luke
Could this lope be the intake heaters kicking on and loading the alternator? the head lights may dim when this happens.
