Originally posted by midlife crisis
Well now, dont I feel like a jacksss. I was sure the injectors were fired by the computer, connected via an electrical connection. And you further correct me by telling me there is no way an injector driver, for whatever reason, couldnt be keeping an injector open, or timed wrong. I stand corrected.
Man I love sarcasm... The injectors ARE fired by the computer. They ARE connected via an electrical connection. I never said they weren't. I also never "corrected you" by saying an injector couldn't be messed up and therefore screw up your timing. All I'm saying is no matter how long the injector is held open, there's still no way fuel is going to end up in the crankcase oil unless there's a MECHANICAL problem... something has to be leaking somewhere. There's no path between the top of the cylinder (where the injector dumps, in a case of stuck injector as you mention) and the crankcase, unless there's a problem with the cylinder, piston, or rings. I would be glad to admit I'm wrong if someone wants to enlighten me with some knowledge that I might not be aware of instead of a bucket full of cynicism.
