Engine missfire
06 turbo help/questions
Stutter in reverse after Transgo and Sonnax Upgrade
I have a 05 5. 9 L which will stall and check engine light comes on; sounds like running on 4 cyl's. I have replaced wiring inside the valve covers, repleced connectors on outside of valve cover and problem still occurs. Has anyone had this problem before?:#@$%!
I didn't look up what that code means, but something I read in the past-
If there happens to be a failing (shorting) injector, I think the module that drives the injectors will shut down pairs or three's of injectors in a gang, as it protects itself. I'm pretty sure I read on here some months ago about a guy who was having similar issue, and it turned out to be a single injector shorting. So, that's something else to consider. Please do post back what you find.
