Until recently, I've focused on fixing the suspension on my truck. Now that I have that pretty well taken care of, I'm looking at performance modifications. I'm not looking for huge HP, something in the 320-370 range. Currently my truck engine is stock but I've put on a new exhaust manifold, 4 in exhaust, and intake filter. My understanding is that new injectors, delivery valves, and fuel plate are the three primary things I can change that will increase/decrease the HP and torque. My question is do I need to do them all at once or can I do them independently and still see performance changes and when I make the improvements will I have problems because of injector pump limitations
For the injector replacement, I'm considering either 215 or stage 2 injectors. From what I understand the 215's should actually improve my HP and may produce better fuel economy while the stage 2's will produce about 20 more HP (then the 215's) but not affect fuel economy from stock. My question here is 20 HP really noticeable?
A local shop suggested putting in new delivery valves first. They felt that was the key to more power. Another shop stated there is some disagreement that delivery valves will improve horsepower but that they had changed the delivery valves and noticed improved an improvement in performance. Does anyone have any thought regarding the effect of delivery valves?
I hadn't considered a fuel plate but looking at the various kits it seems that I may limit the value of the injector changes if I don't. Can anyone speak to that?
Basically, I'm just trying to determine the best sequence of improvements given my limited budget. I know that was a lot of questions but appreciate any comments.
