I can see how the . 78 ratio could be seen as an underdrive, but rest assured it is how they calculate the overdrive - take the speed and divide by . 78, and that will give the overdriven speed, verses multiplying by same ratio
. Think of the numbers the same as gears in a transmission - in a NV4500, 1st is 5. 61 (engine rotates 5. 61 times for every transmission single output rotation), 2nd is 3. 04, 3rd = 1. 67, 4th = 1. 0 (direct drive - one engine rpm = one transmission rpm), then 5th is 0. 75 overdrive (engine rotates . 75 times per every 1 transmission output rpm, or, the transmission rotates more times than the engine), then, add the GV (. 78) and the engine rotates . 78 times for every overdriven (. 75) rpm of the transmission. With my setup, at 65 mph in 5th gear, with 4. 10's and 35" tires, the engine is turning 1900 rpm. Then, divide that mph by the . 78 GV ratio, and you get 83 mph at 1900 rpm.
I just re-read all that and gave myself a headache. Must add beer :-laf
And no doubt it's a lot of driveline
, but it is all mated and all precision-aligned {cool}. The whole kit and kaboodle is pretty nice - Gear Vendors really did their homework on these units, and the adaptors are sweet.
The funny thing is, considering the rig I'm building and the overall chassis length (about 24' total), I'll still need a two-piece rear shaft
- M2
