Somebody asked that question at May Madness, the Rep from Rocky Mountain Cummins was there to answer questions. He said go ahead and shut it down, it doesn't hurt anything. The turbo is watercooled so you don't have the same temp issues as the earlier gens did. Also, the regen mode is automatic and will resume when you drive it again. As far as an indictor light, he said Dodge didn't want one because our trucks are consumer products and it would likely confuse most people. The regen system is designed to run in the background.
My personal experience has been that it must be in Drive to regen... ... ... ... .....
Bob
How difficult could it possibly be to have an indicator light to signal a regen taking place? Maybe even a switch to allow the driver to start one at will. I know all of this has been gone over before but what could possibly prevent them from doing this?I am assuming that some aftermarket programer manufacturers could make something like this for people who want to keep their trucks"green".
I really love this truck but would really, really like to know more about what is going on under the hood (or under my seat) than Dodge or Cummins is allowing us to see.
When I took my truck in the last time they told me the computer showed I had numerous Regen attempts but hadn't had a successful one in a long time, I am at 20,000 miles. So they cleaned up the o2 sensors and took it out to the freeway for the 45-50 minute drive. My Dashhawk showed 0. 0 for the first time for the 'Regen Filter', the lowest I had ever seen it was 2. 5 which counts down backwards when it goes into 'DeSOx' mode. The 'Desoot' mode seems to happen pretty often and lasts 15-20 minutes. Another of the PID's I can monitor shows the 'Regen Trigger' at 4. 5, I can only assume that when the 'Regen Filter' reaches the 4. 5 figure that it then looks to go into 'DeSOx' or the drive it at highway speed for 45-50 minutes. The 'Desoot' appears to stay active as long as I am in drive even if I am stopped at a light and if I do interrupt it for any reason (in park or shut the truck down) it starts back up the next time I take off. However the 'DeSOx' mode of regen doesn't appear to be so easy. I understand the 45-50 minutes at highway speed but what are the other requirements? It's apparent that once it starts it has to complete the process all at once and wont allow you to stop and continue it the next time you start up. Does anyone know the sequence for this process and it's requirements? What is the minimum speed required or is that even the requirement? What will kill the process and why wont it just start up again like the 'Desoot' does? I don't do much long highway speed driving so when it wants to 'DeSOx' I can pretty much plan on it not being able to complete the process, unless of course they would have provided us with a way to manually force the 'DeSOx' without having a StarScan tool. It's become quiet apparent that the DPF systems on these engines has become a pretty important thing so why not provide some data like we get from our Oil PSI and water temp gauges? We are basically getting 'Idiot light' information via the EVIC when it's too late, kind of like the old low oil pressure light... too little too late.
HBarlow, I do remember you asking the questions regarding this issue. I also remember the speaker being familiar with the Dodge trucks or at least telling you that he was. I don't have a new truck but was interested in the info being shared. What I heard and I could be mistaken, was that these trucks are designed to regen without the owner being aware of the process and that shutting down during the process was not a problem at all. It is automated and will resume when the truck reaches the required speed/temp to do so. He did state that if you were pulling hard up a hill and came to a stop it would be wise to allow a certain amount of time to let temps equalize, but other than that shut it down. I don't think that the average owner pays as much attention as we do to the operating details of these trucks. Other than the turbo being cooled, I don't see that the excess heat in the DPF would be any problem since that is what it is for, an oven of sorts. Any engine would benefit from a cooldown period after running hard and certainly letting the pyro tell you when to shut down is not going to cause any harm other than having to wait for it to cool. I can see though that an indicator light would be a nice feature to have.
