What is considered "normal" engine temperature for our trucks ?
When I had the scan tool hooked up, I noticed mine was runnning around 158-160 degrees. Would engine temperature have any effect on the transmission hunting ?
I was checking the voltage on the TPS and noticed that the voltage was jumping all around. I cleaned the TPS with TV tuner cleaner from radio shack and everything was fine for about 30 miles and then it started hunting between 3rd/OD again.
TIA
TIA
