Well, gang, I made my run with new gauges, and the EDGE, the only mod I've added. The loaded condition is a 8,000 lb 5th wheel trailer. Here are my temps at 65 and/or under load:
EGT: unloaded 500 loaded 1200
transmission: unloaded 125 loaded 210
REAR AXLE: unloaded 150 loaded 150
FUEL PRESSURE: unloaded 8-10 psi, loaded 5psi
The max temps occurred on a 7% grade at 3,000 ft (Blue Diamond road or HWY 160, out to Pahrump for the locals). I was able to maintain 55mph. Before I added the EDGE I had to drop down to 40.
Are these readings ok?
What are others seeing when under similar loaded conditions?
