Here's the scenario. Had Westach fuel pressure gauge installed 2 wks. ago. Shop mounted the sender on the side of the engine even though I told them to mount it near fender. Sending unit has grease gun snubber from bottom of fuel filter housing. 68k on truck, 01 ETH. Right after install saw 9-10psi at idle 0 cruising at 70mph. Assumed bad lift pump. Yesterday installed newest and greatest lift pump. 15 psi @ idle, but will drop to 0-3psi running around 70. Seems to drop most around 1800 rpms. Fuel filter was changed about 7k ago and I will put a new one in this weekend, but was wondering if the engine vibration could be causing the fluctuation or if someone has any other ideas. I think for peace of mind, I'll remount the sending unit away from the engine and see if it helps. Any thoughts/suggestions would be appreciated.
