Check the connection of the cable to the transmission. Mine came loose and wore the pin off that comes out of the 90° "differential" that goes from the transmission to the cable. The pin is replacable so you don't have to buy the whole speed reduction/increaser kit. This little 90° gear set calibrates your speedo to the model of your truck(rear end ratio, tires etc. ) At a speedometer repair shop the pin was $1, the speed reducer was $80 plus they needed the number off of it to be sure of the ratio. Ya right after 300,000 Km?
Also, the nut on the final drive out of the transmission/xfer in the yoke could be loose. Give that a good torquing if the above is OK. I don't know if this is true on the W, but the D it can be problematic.
Hope this helps.
Jeh
Jason Hoffman
Lil' Mack - 89 D250LE 5 Spd 3. 54 Reg Cab. K&N,"tweaked pump", BD Injectors, Banks Pyro/Boost, 3. 5" Exst tail section straight. E&M Custom seats. Bosch H4, PIAA 80W/80W HdLites. 100W Drv,55W Fogs. 237,500 miles (380,000 Kms) 7850 Hrs.
Cummins Power Booster member.
The Original Turbo Diesel
Lil' Mack Pics
Hope this helps.
Jeh
Jason Hoffman
Lil' Mack Pics
