Error Codes P2228 and P2229
AC go BOOM!
Serpentine Belt 2012
The above codes (Barometric Pressure Low and Barometric Pressure High) are showing as Permanent on my OBD2 reader.
I screwed up this morning after changing the accessory belt and started the engine before hooking up the Air Intake Temp and MAF sensors. Check Engine light was lit. I reset the error codes and started the truck. The Check Engine light went out. After the restart I went back in with the OBD2 reader and the above codes now show as permanent.
The confirmed codes window shows as clear and the pending codes window shows as clear.
Am I OK or is there a problem?
Thanks,
