Yes. They drilled a hole in the top of the tank, cut the pickup tube to length and mounted the assembly. The pump is right at the top of the pickup tube (pushing is better than sucking). The wiring for the pump and the fuel line were ran up the inside of the frame to the unit at the front. I think that a person could install this unit at home if you are mechanically inclined and have the time. The instructions that come with it seem to be okay. Hope you have luck finding a source for one.
